Blinder Button create
I would like a blinder button on the Live page I build a preset, made a button that engages this while it is pressed. it’s working only when no preset or sequence is chosen. How can I make it so I can use it while sequence is running?
Running the 128 dmx channel subscription
Kind regards
Good news, this is totally doable, I use blinder buttons like this all the time and they work fine with a running sequence.
First thing to check, are you in Live mode? Tap the BeatTracker at the bottom right of the screen, then switch on Live mode. That’s what lets you stack things on top of each other.
Then it’s all about the order you press things. Start your sequence first, then hold (or just push) your blinder button: the blinder takes over while you hold it and the sequence keeps running underneath. If you press the sequence after the blinder, it grabs the channels back, so always sequence first, blinder second.
If it still misbehaves after that, send me an export of your show and a screenshot of the buttons, I’ll take a look.
Cheers
