Hello,
I have lyres with a color wheel. I created a simple up and down movement and I would like to be able to create buttons for each color of the wheel. when I change color my movement stops. What can i do ?
Thank you
Hi and welcome @Eric !
Sorry for the response delay…
To do that you have to create presets (or sequences) that manage colors ONLY.
It is the same problem that on this topic but for colors : Transition Time in Sequences - #2 by Cclleemm
Make sure that only the “color” icon is active on the preset. This way, when you activate it, the moving heads will keep moving and the colors will change.
For more info on the presets go here: Create a preset - Photon Docs
