How do you configure Chauvet DMX-AN2 Reciever?
Also keen to know.
I did have it setup but lost my settings and can’t remember how I did it last time
I ended up resetting the AN2, logging into its webserver then matching the IP to the router I’d be running through, and gateway to whatever the photon setting said (255.255.255.0 from memory)
and I had success with artNet rather than sACN
I wish I could help you but I don’t have this device at my disposal. However, if you make the solution work, don’t hesitate to attach some screenshots of the configuration, it could really help other users!
Thanks a lot for your participation
@kellyburt, did you plan to use ArtNet or sACN?
