Using Photon 2 (Starter level) with an iPad, DMXking eDMX1 MAX converter, and about a dozen lights on a designated wifi network.
Wanted to get some guidance on how to troubleshoot a multi-second delay I occasionally see. I need to do an instantaneous trigger for some lighting actions. Usually, when I am testing everything at the start, everything is very responsive. Occasionally, usually later in a show, when I push a button on the Live mode, it will be several seconds (e.g., 5 seconds, 20 seconds, 40 seconds) until the action takes place (e.g., light turning on, light turning off).
I have wireless DMX as a good part of my setup, but when if I move stuff to wired DMX I see the same behavior. When I look at Photon 2’s DMX channel view, the commands take effect right away.
The wifi is very congested at this location at moments, but I have moved channels and the issue still occurs. It feels way too long to be a networking problem, but that is just a hunch. I have switched Photon 2 from art-net multicast to art-net unicast and sACN. Feels a little better but still a much longer lag than I feel is reasonable.
