On the Live Screen, is it possible to set/enable the buttons so only 1 is active at a time? What seems to be happening is that I need to issue the same MIDI command (or press the button again) to “turn off” the existing active button before moving on to the next. If every button defaulted to “off” whenever another button (or MIDI message) was pressed, this would make the behavior more consistent (similar to how things work in the Light Control screen). See video below:
Example of button behavior between Light Control and Live screens
