The first day I used it , it worked perfectly fine but than after I used it again and again I felt input lag. Anytime I pushed a setting it would take a while … is that issue with app or wha?
Hi
Do you have a big project
What is your iPad model ?
Thanks
Not really, it’s just my Uplights around the ballroom.
I have iPad Pro 12 inch one (4th Gen)
If you reboot iPad the lag still here ?
There are some possibilities that may be associated with other apps accessing Virtual Midi, Virtual Network ports etc. See if performance improves when you disable Bluetooth on the iPad. I am assuming you are using a router to run DMX?
