I have Photon 2 on my 10th generation iPad, version 26.5.2, I have the app dashboard set up to operate 26 fixtures. I have every square on the dashboard loaded with buttons/faders. The dashboard is (was) seven rows high, 12 rows across. To connect the iPad to the lights I am using a PKNIGHT easy node to a 3 foot DMX cable to a Donner DMX transmitter.The iPad always recognized the easynode, and the system worked for perhaps a year or so. The app would occasionally crash while editing, also it would crash if I made scene changes too quickly, that is one right after the other. Generally, it worked and did what I programmed it to do
Well sometime ago finished a gig with this system and packed it all up. It was working fine.The very next night I set it up and the i iPad connected to the Easynode as usual, but the app would not operate the lights. I got through the night by setting the lights to run on their own.
Looking at the App Store, I tried to re-buy the lesser $49.95 app, but after tapping on it, it never seemed to load, I was never charged, and now my Photon 2 app dashboard is changed. The bottom row on my dashboard is missing. You cannot see the highlighted blocks where buttons would go. Also, while looking at my different shows, I noticed the top left corner had some buttons partially showing. So I put it in edit mode and was able to drag a couple of them back to the dash. They will not sit in the bottom row though. Also, when I do get to move them, they are larger than a single block, but not the size it would take to fill a double or even a four block space. They seem just a little bigger like 1 1/2 times the size they’re supposed to be.
I’m not sure what I did wrong, or if there was a problem with the app. I do have another small DMX.lightboard and plugging that in with the Donner transmitter/receivers the lights work fine.
I’m not sure if I have caused this problem or if the app is somehow locked up. It opens right up like it always did, and my shows are right there, I can tap one and then I get the “modified“ dashboard with the bottom row missing and nothing works.
I know that’s a lot, but I would really like to get my Photon app up and working again.
Thank you!
