Hi Photon team,
I had buy the pro version due to this version support background mode. However, when I screen off my iPad mini, background mode works only for a while. I use PAR to test, The sequence is R RG RGB RGBW RGB RG R blackout then repeat. However, when I screen off the iPad mini. The PAR run sequence as excepted but only for a while. I had created a button on live view with sequence. The PAR then freeze at one preset. When I screen on again, it resume normal and keep running sequence. When I test the same sequence with Photon free version. The PAR freeze at once when I screen off my iPad mini. So I think background mode is working but only for a while. I am using iPad mini 6 with iPadOS 16.1.1. Thanks.
Did you activate the Live-mode? As far as I know, Photon stops working in background after 2 minutes if it is not active (if you allowed notifications, you should get one).
Hi Flupsi,
Before use Photon, I think I am using ‘Live’ mode until you ask. Then I check for myself and found that a red ‘Live’ stayed on lower right hand corner. This is a real ‘Live’ mode. I had not allow notification to pop up. So, I can’t see the message you show.Thank you.
We don’t send other notifications with photon, the only notification is to tell you go on background with active project
Hi djgreg13,
Thanks for reply, I am still new to Photon. You Photon team make a great program. Also with community let us to ask. I will going to allow notification.
