Greetings. I have an old box that still works with other software. Any chance it would work with Photon? Also what is the minimal iOS for functionality?
Thanks.
JP
Thanks.
JP
Hello!
You need iPadOS 14 or newer. If your box supports Artnet or sACN, it should work. You can test it with the free Photon version (if your iPad supports Photon. If not, I think you can test it with Photon 1 (iOS 10), the basic settings should be the same.).
Wifi 5/6 or usb to Ethernet is better for best frame rate on output
Thanks gents. I was hoping to repurpose an old iPad 2 but it looks like I will need a newer iPad. I will test with my iPad mini 4 for now.
