Good morning!
I’m having trouble connecting my Eurolite ArtNet Dmx Node 1 with photon via my WiFi Router. The Scenario:
iPad connected via WiFi to the Router, Node connected via CAT6 to the Router.
Configuration:
Router:
- fixed IP-Adress 10.0.0.1,
- Subnet Mask: 255.0.0.0,
- DHCP off
Node:
- fixed IP-Adress 10.0.0.2
- ArtNet-Universe 1 (first universe is 1)
iPad:
- fixed IP Adress 10.0.0.3
- Subnet Mask 255.0.0.0
- Photon: Multicast, Subnet 0, Universe 0. Also tried Unicast to 10.0.0.2, did not work either
Is there somebody who could help me please? Thanks in advance!
Greetings from Germany, Ludwig
Do you have tried to put photon at universe 1 ?
thanks for your answer! i tried, but it did not work. In my opinion Universe 1 on the node and Universe 0 on Photon is right, belonging to the users Manual of the node.
My bad
Artnet universe 1 mean subnet 0/universe 0 in photon
What is your os version, did you allow network request at launch ?
I’m in iPad OS 14.4, iPad Pro 12.9 2015.
Everything is allowed, if I output ArtNet to the PC, everything works just fine. I just cannot output ArtNet to the Node.
Greetings, Ludwig
FIXED:
Just switched the router and tried in the default 192.168.2.x- setting with dhcp on and manual IP on the node. Now everything works as it should.
Thank you VERY much for your time!
Now I’m ready for Photon2 ;D
Some nodes has problem with big range networks
Issue resolved, so I
Photon 2 is on beta on TestFlight
you can beta test this major update
Dear
