I have a problem I’ve just noticed, to do with the dimmer faders on my fresnel channels.
I have some LED fresnels (BeamzPro BTF300Z) that I’ve made custom profiles for. (I run them as two channels, channel one is a standard dimmer, channel two is a mechanical zoom.) I put each fresnel in its own group (1 device in the group) so I can control each fixture separately. But I also put all the fresnels in a fresnel group (4 devices in the group) so I can control them all together. It works well, but the fader for each group only gives you 50% gain or cut. If you just use the fresnel group fader, the lights only go up to 50% output, even though the fader is at 100%. And if you just use the individual fader group, same result - the light only goes up to 50% output. If you use both faders and boost them both to 100% then the light fixture does indeed go up to 100% output. Similarly, bringing each fader down to zero will only bring the fixture down to 50%, you have to use both faders to bring output down to zero.
Some comment or help with this would be appreciated. Is it because I’ve put the same fixture into two groups that each fader only controls 50% of the dimmer range? It was the only way I could work out how to have individual control and also have it as part of a group. Is there a solution to this? Thanks!
