Thank you for your Software.
I use the Software quite successfully, however Im having troubles with a single dimmer module. I have only one channel to control, but the light is not dimmed but turns in a very fast on and off. With software on my PC like DMX Control it runs smoothly. Any idea what I’m doing wrong?
Hi!
This is weird.
We had a bug in the last Photon version (with dimmers), please try to update your app, then delete the device and add it again.
If it doesn’t work send us an export of your project (by touching the select then the share button on the shows screen).
Thank you !
There was an issue with 1.7.3 and 1.7.4 with dimmer.
I suggest you to download de 1.7.5 update.
And you tell us, you use a pc with DMX Control, please ensure the pc is not sending artnet trames on same universe/subnet, your artnet module is not supporting two nodes streaming on same universe.
Since I was curious, I did some tests with other apps and it is all the same on iOS:
If I connect only one or multiple dimmer, it is all fine. However once I connect different other devices, it turns strobo though channels are at a completely other channel. Has anybody had this before?
If device reacts at the same, maybe there is a problem with dmx transmission, can you control the dmx output on dmx wire ?
Another devices has impacted ?
