I received yesterday my new eDMX 1 max (the pro version of the product is not yet available) but I am not succeeding to close the ring between Photon 2 and ligth. I am using a router, Photon 2 on IPAD. I set scene 0 on EDMX and scene 1 on Photon 2 but I cannot get to control my light. Is someone working with eDMX 1 max? When I select Photon on the eDMX MAX Configuration tool I get the following a message “Firmware 3.3+ only supported. Use earlier version of eDMX configuration Utility v1.x for eDMAX pro series update to latest firmware”
I received an eDMX 1 max, I didn’t try it yet. I should to help you.
Did you fix your problem ?
Hi, thanks for your message. YES, after some different configuration the problem was fixed and I succeed to use eDMX 1 max. Now it works. Thanks again
Cool ! What was the problem ?
