Hello, (SorryPlease my Englisch no good)
Thank you for your work, this app is great.
Now I’ve found a buck though, it’s 100% your app. Why am I saying it’s your app? As it doesn’t happen with other apps via PC. Not too bad and you can fix it, that’s why I’m writing to you, your app would only be better together.
To the problem:
No matter what program is running, the devices don’t matter.
An example:
I go to a group “PicoBeam 1 \u0026 2”, are my 2 moving heads, I programmed them into a group in the app.
Go to Custom Control to call a batten I set, for example Program 4 (The device’s own programs are called/controlled with it.).
It also works for a short time and the 2 moving heads run in sync.
error is:
After some time, the app will send an error signal to the devices and they won’t run Sycron anymore.
It runs for hours on the PC with the same interface without errors.
This program also runs for hours on an iPad without errors. Tested with the “DMX Monitor” app, since I only call up/control the device’s own programs.
In order to rule out errors and get the results that it is up to your app.
Please fix the problem, thank you!
Sincerely
Sven Hornung
