Are you able to add parcan to your device list as per the details below please?
Event Lighting PAR12X8L - 12X8W LED RGBW PARCAN
I will check if I can add it soon to the list. Did you tried to create it with the app ?
I will keep you in touch.
Thank you for using Photon !
Hi, I just created your fixture in Photon.
You have to open and kill the app twice to update the fixture database.
You will find it in the Event Lighting section (9 ch. mode)
Thank you so much for setting up this device.
Works perfectly.
Your welcome ! I hope you will enjoy Photon
