It’s a good product , I like it very much.
by the way ,the app works well in Unreal Engine , (use DMX protocol )
Hope you can upgrade it , step by step.
1 Each time after I resetup my CustomDevice, It bring two issues:
- It didn’t apply the config automaticly, I need to delete all the devices which I used it before.
- when I delete the devices, I need to do it one by one .(it’s hard when you have 20 more devices)
2 Hopefully , you can add more custom function in the fixture library. Like:Gobo,Frost,Focus,Zoom…etc
that we can control it in the intergrat first Control-panel . and the functions which the devices don’t have them ( by the devices), it should not appear in the first Control-panel.
3 The core issiues: After I group the devices, I still want to indenpendently control the device . Otherwise , I just set the devices into the same dmx address , right? especially , the Moving Head… you can understand.
4 It’ll be better when there is a language option in the app panel. in some situation , I just want to compare the names, and let different groups coordiate together.
by the way , you can upload some config in the unreal shop. I set it manually.
more and more people will join you.
Thanks for your patience!
