I’m using the free version for testing and I got everything to work, but there is a small delay, smaller than 1sec , maybe half a second on the changes, ongroup view and live. I’ve tried multiple types of connection (Using a router and wifi, using a router and and cable, and with ethernet directly - setting the unicast to the interface’s IP) in all cases I get this delay. I’ve tested in other apps and they switch immediately on presets change and flash buttons. I really want to buy Photon for it has the features I want but I cant cope with this delay =/ even if it is this minimal.
The DMX interface that I use its a generic one (Its the best I could find where I live) but I dont know if it can be the issue since I can get it to work on the other app.
I’ve streamed from photon to DMX Monitor and there was less delay but I think it’s relative to the number lighting up on DMX Monitor. Then I tested with the other app and there was no delay… so comparing both, photon has a delay.
I don’t know if this is related to the variable frame rate that you talked about, but I’m sending some pics of the DMX Monitor monitored universes.
