I try to control a hazer that only has a single channel. It controls off and amount (dimmer) without any timer. I added a button to Live Dashboard that turns on and with fade.out (logarithmic) in order to run the hazer for 20 sec, which is max. fade-out time (would be nice if it was longer). Is it possible to make a timer that enables the hazer periodically with a duration. As an example activating the hazer every 5. minute for 20 sec
