Currently, when creating a sequence I think you can only add presets. However, it would be great if you could also add a sequence (of course it would run only once in this mode). For example, I have a sequence in which all my PARs individually “chase” around the stage (one at a time very fast). I would like to add this behavior as part of a larger sequence but cannot. Maybe for the “next beta”? Thanks!
It is a good idea, we just added it to our todo list. It is a sequence of sequences and presets
Just following up to see if the “sequence within a sequence” feature has bubbled to the top of the to-do list?
Hi, how are you?
Just so you know, we’ve got other priorities like multi-dashboard and effects. Unfortunately, I don’t think we’ll be integrating sequences into sequences any time soon. But it’s still on our todo list.
Keep the dream alive Clem! Just sayin’.
Be a great thing to do. I have a couple of sequences and it would be good to be able to run them one after the other and have some other presets in between.
I think the current best method to do this would be midi-mapping your sequences, then creating a loop in Ableton Live (or other external MIDI sequencing app) which activates your sequences in order.
Yes, please!! I’d need this too.
