I just purchased the pro version and have some feedback. I’m curious if some of my concerns are user error, or if there’s workarounds or fixes for some of the issues I’m seeing.
Currently I have 2 Chauvet 4BAR Quad ILS devices.
I just purchased the pro version because I need MIDI trigger support.
- First Issue: Can’t buy Pro on a Mac, nor can you “Restore Purchases”. I designed a bunch on my Mac, realized I couldn’t upgrade, so I bought it on my iPad.
Clicking Restore just spins for ever.
Is this a known issue? Is a fix in progress?
Second issue: No sync between devices? I also assumed that my shows/devices, etc would be stored in iCloud and that my iPad would pick up my work. This is a minor issue because I know you can export/import projects, but something that was surprising.
Because my lights aren’t in the database at the moment, I had to create a custom device. (I’m using 19ch mode so I can individually address the 4 lights in the fixture). Creating this was pretty tedious, and I started small with just the lights.
Then I added my fixtures w/ their starting address.
Then I tested to make sure it worked.
Then I went back and added Dimmer & Strobe.
But the fixtures don’t auto update from the device they were based on?
I’ve had to delete & re-create the fixtures numerous times as I iterated on the custom device. Very annoying.
- No way to individually address colors for 4 separate lights in a single fixture. There is only 1 color control in a group, and it controls all of the lights equally. In order to do this I had to:
- Create a single “device” that controlled Dimmer/Strobe/Built-in Programs for the overall light bar.
- Create a separate “device”, to represent a single light. These had custom sliders for R, G, B, A.
So for my 2 light bars I now had 10 fixtures.
Then I’d have to create 10 groups so I could address them individually? At this stage I was questioning the whole process.
Any tips on how to do this in a better way?
Thanks for reading. I do like the app, but my initial setup was pretty frustrating and I’m hoping there’s some answers for my questions.
