I am writing to you for the first time. I run your application on an older iPad Mini2 - iOS 12.5.1, which I use exclusively as a light and at the same time a sound console. Until recently I have used another application for lighting. Your application got my interest since there are several options for setting up your own accessories and sequencer options. I use rotating heads, RGB led PAR, animation laser and DMX Haser. I have set up all the devices separately and they work flawlessly. As I mentioned before, I also use an iPad to play (stream) music via Bluetooth and at the same time to control the lights via WI-FI. Synchronization via Ableton Link also works reliably (Split View mode).
However, the only significant problem for my use is that the application switches the played audio output to the internal speaker at startup and it is not possible to switch it back to Bluetooth in any way! I tried to play audio directly through the iPad and through the application I use (Cross DJ) but it didn’t change or fix anything. The application I used before didn’t have this problem, but it allowed you to use a microphone to sync when playing audio. (I used Ableton Link to sync)
Is there a way to solve this problem?
Thank you for your answer in advance.
Best regards
Boris
