I notice current app limit the maxium numbers of universes to 15, is there a way to set the universe number to a higher number, for example 101 or 201.
I am not sure if this is a limitation of the app, or some settings I need to set, each time I set the number to more than 15, close the setting panel and go back to the setting, the number jump back to 15.
Thank you.
