I have a HQ Power LED Bar with 3 segments and 13 channels.
CH 1 Function selector
CH 2 Red dimmer
CH 3 Green dimmer
CH 4 Blue dimmer
CH 5 - CH 13 Adjustable brightness from segment 1 to 3 in RGB
If I create that in the App I can control the Function and the dimmer for the different colors. But I can not adjust the different segments…
Is that not possible?
I have a Chauvet 4 in 1 and I create one master device and 4 sub devices
My master device set the global dimmer and shutter properties
Subdevice has one rgb property
I mapped one master and four subdevice
I mapped one in a global group and two si device left and two si device right
Photon doesn’t really support this natively, so they are not in global database
Yes that works.
Thanks for your help.
I have some RGB LED battens I made and wanting to do a similar thing. I have used Lightkey in the past on the Mac and I just setup a barren them I can control the different sections of leds to have different colours / chases etc along the battern.
Is that possible?
Thanks
