Dynas
August 22, 2024, 2:30pm
1
In the Light Control Tab, in the change device panel (Dimmer/Strobe, Color, Location…), could you add a quick light selection feature ?
For example :
a line of all lights, like in the live session, then you select on the light (then, no need to come back to the all devices list)
Indeed, with many lights, or bar with individuals pixels, there are too many devices on the screen.
Kind Regards
Dynas
Dynas
August 24, 2024, 12:29am
2
We could add in this feature a solo mode when edting.
The goal of the feature is to avoid a return to light control pad and to directly select the next color to change.
I really like the app although ! I’m just playing with the app without the light yet
Dynas
August 25, 2024, 4:42pm
3
I will add some ideas through my use of the app…
Also, could it be a menu reacpitulating all colors use, or a quick access to last used colors, next to the color Whell selector (and primary colors).
Dynas
August 25, 2024, 5:26pm
4
Hi again,
In live Menu, It should be also nice if we could copy/paste a button/Slider, that would directly create a preset.
or, it should be good to be able to copy paste many Sequence, in order to have the same base, and then, change the set of colors.
I keep testing the app.
Kind regards
