When using a fader (tap+hold+slide) on the live dashboard, I have to slide / change the value by about 5% or more before there’s any response. This means I can’t accurately control moving heads until this “hiccup” occurs, or change brightness smoothly, etc. Really makes following performers with spot lights (manually) quite difficult.
Note that this behavior is easily replicated on any live dashboard fader for me. Faders work fine as long as I don’t release my touch on the control. However, if I lift my finger (or mouse point) and have to tap+hold+slide the fader again, the issue will occur again.
