Hi would it be possible to implement midi control of both the ‘Master’ fader and the ‘Blackout’ button on the dashboard plese?
Cheers
Cheers
Good suggestion !
I will add it to our todo list. Thank you.
How do I assign midi to the blackout and Master?
thx
Hi, As you can see from my request for that feature above - it got a quick response from Devs and added to the ‘todo’ list, sadly not implemented yet.
Fingers crossed for the next update!
Just FYI, I created a blackout scene with all my lights blackout, and do call that using midi. Works fine… not using the blackout button, but has the same effect on my stage and I call it with a footswitch.
yes i’ve done the same, but if there was a way to command the already implemented blackout button it would have been great, but more if the master fader could be attached to a midi command
