I have a fixture that has 5 different sections (leds) that can be independently controlled for color. If I add multiple mapping for color in the fixture editor I have no where in the group controller or anywhere for that matter to select what color wheel I am implementing.
Welcome on the community !
If I understand correctly, you have created a single device with 5 x RGB channels.
If all your channels are in the same fixture and therefore in the same group then you will not be able to control the color wheels individually.
I advise you to divide your fixture in several fixtures and then integrate each fixture in a different group.
So you will have 5 independent groups on your dashboard.
It’s not really pretty, it’s a bit of a fiddle, but one day we’ll have to deal with subset devices properly.
I have 14 colors with my moving head, I was also thinking to have a color wheel or palette with 14 buttons (or customizable qty with predefined colors). Right now I have no use for the color wheel with my actual mapping. Any ideas would be really appreciated. Thanks.
