I was testing my configuration today. While playing and skipping between different modes (manual / automatic (built-in mic) the bpm counter just “stopped”. Well, it was running but syncing to the wrong bpm. It was static at 120 bpm even with “automatic (built-in mic)” activated.
Unfortunately, I can’t reproduce the issue because I clicked a lot and activated different sequences / presets all the time.
Just wanted to let you know that I encountered that issue.
Did some testing a few minutes ago. Activating a a sequence and switching between presets (manually in the “Light Control” tab and the BPM is “static” at 83-85 BPM.
The visuals are jumping like wild (loud input) but the BPM stays at 83-85 BPM.
Troubleshooting: switching the mode to “manual” and hitting the screen adds bpm up to 180 in my case. After switching back to “Automatic (built-in mic)” [with a line in connected] resets the BPM back to 83. Same with Ableton Link.
Switching in and from “LIVE”-Mode (Showtimemode) makes no difference.
Restart of the app obviously fixed the issue. Working fine after restart.
HAHA got it reproducible! Not the first one (with the static thingy at 120 BPM) but the problem with the 85 BPM. I started a song with 100-130 BPM (depending on section of the song). After clicking some presets & sequence heavily, it switched to the 85+ BPM thingy.
After 2 min not adapting to the incoming sound I pressed some buttons again and it started adjusting the BPM to the sound. Is the BPM recalculating after each preset/sequence? I attached the video below and hope it’ll help
By the way: Locking your iPad (no Live-Mode activated) with running music and then unlocking it also stopped the visual graph and bpm of my beat tracker in one case.
