Is there a way I’m missing to save a level for the group in a scene?
Say Group 1 is 50, when I exit the app. I want to to return to 50 when I go back in. It doesn’t seem to do that or am I just doing something wrong. Otherwise really liking the app. I’m just using it to control the brightness on some spots, so I’m not after anything complex.
Using free edition, happy to purchase to include the save feature, it didn’t look like that was a feature.
All the groups remain, the problem is if I set the lights to a level. Close the app. Go out of wifi range or simply put the ipad to sleep. The lights remain at the current level (good, that’s what I want).
The moment I open the app again they go to a different level (bad, it will wreck the setup in an event when the app reconnects to Artnet, the levels on screen are different to when the app is closed). I hope that explains better. That’s the only fault I have for the app for how I wish to use it. It doesn’t “save” the last state of the levels when you exit. (eg: iPad crashes, needs to be rebooted etc).
Appreciate any help/advice.
Usage:
Simply using it for dimmer and zoom control on 12 white lights grouped in 3 groups. Not a very complex setup at all. Was after a simple application that has sliders essentially. It fits that quite well. The lights have Artnet built in, the first light controls the rest via the DMX cable. All that part works.
