Sequencer doesn’t work for me. Normal light control works fine but the sequencer parts doesn’t change to the different cues when you press place on the sequence
Hello ! First of all thank you for your purchase.
Can you send us a screenshot of the sequencer view (or an export of the show) please ?
You can export the show on the main screen by selecting the show and touching the share button.
When you create your sequence, how do you add the cues ? Did you select them in the track pop up ?
it’s weird, we’ll make it work
Hi @smacleod10!,
I hope you are well. I realize that we are now in June of the following year, over 6 months on from your original post. I was curious if you had solved your problem or if you still required assistance.
