just saw 2.6 had down loaded, Signed up for the full version to try everything out.
particularly adding Dashboards - and its NOT working.
I have a 10.5” iPad Pro 256Gb - only half Used (Model MPHG2b/A) running latest available for that hardware = 17.7.10.
Either existing show file or made a new blank show, Go to add Dashboard, Create, - FREEZE…
I have rebooted iPad - same result…
Regards
DG
Not good ! Thanks for sharing this major issue.
Can you try please to let the app freezing, then after 2 minutes it should crash. Launch the app again and send us the crash report ?
If it doesn’t work I have another idea to send us the report.
And of course, sorry for this, we will fix it quickly !
We reproduced the problem, no worries.
Can you try to add a dashboard with the + button on the right top corner on the Live view and tell me if it works ?
Don’t have case number to send Diagnostic report? Will try again with Logging turned on
DG
Yes - adding dashboard using the + at top right of Live view works.
DG
Photon-2026-03-16-153016.ips (58.9 KB)
Is this the diagnostic file you want?
Perfect!
We have everything we need to fix the issue, thank you very much for letting us know.
You can use the workaround via the + button while you wait for the issue to be resolved in the next few days.
the bug is fixed for iOS 17.5 (we don’t have 17.7). We just submit the 2.6.1 to Apple for reviewing.
This version also includes lot of stability improvements ! Should be available today or tomorrow.
Edit : Apple take time to validate the release, we submitted 2 days ago. Please wait a little bit more.
Apple just validate the app, can you try and tell me if it works ?
Thank you very much
Yes 2.6.1 - the “ add dashboard “ function from the drop down menu works to add and remove a dashboard.
Thanks
DG
