Hi, there are two small bugs In the sequencer: 1. in you use different fixtures in different sequences the last DMX State of Not used fixtures will stay in the actual sequence. So you have to pull this fixtures always down for a new sequence. 2. the Transition out funktion is allways fade out with shutter, Not only fade out.
I have open issues for your bugs.
For the 1. when you tell
Can you confirm the device do nothing ?
For the fadeout transition, can you send me the device used ?
