What hardware do I need?
Hi
I have some questions.
I want to control the lights wirelessly like the attached photo.
First, what hardware do I need?
(Except lighting fixtures and iPad)
What hardware should I use from eDMX1 Pro to ultraDMX2 PRO?
Is it possible to connect all the lighting fixtures with a dmx cable and connect them to the DMX PRO to control them wirelessly?
Second, what kind of lighting fixtures are supported when using the Photon sequencer program?
Can I use these products?
If not, please tell me which product to use.
moving light
https://www.aliexpress.com/item/4-pieces-lot-moving-60w-LED-Moving-Head-gobo-Light-led-dmx-512-control-mini/32724200030.html?spm=a2g0o. cart.0.0.6dac3c00r1ljNj
par light
https://www.aliexpress.com/item/led-par-lights-54x3W-DJ-Par-LED-54-3w-lights-R12-G18-B18-W6-Wash/32858035203.html?spm=a2g0o. cart.0.0.6dac3c00r1ljNj
spider led
https://www.aliexpress.com/item/2017-New-Arrival-CREE-MINI-LED-9x10W-Led-Spider-Light-RGBW-16-48CH-DMX-Stage-Lights/32788240772.html?spm= a2g0o.cart.0.0.6dac3c00r1ljNj
Third, is it possible to turn on and off music and lighting all at once with the Photon application itself?
I want to control music and lighting with iPad.
Thank you!
We can suggest to use a ArtNET or sACN receiver, Photon works fine with receivers presented on the https://photon-ios.com website.
In your scheme, you put the receiver on the spider LED moving head.
So some receiver has integrated wireless hotspot and others need to connect to a WLAN, so if your iPad and your receiver are in the same network, Photon will work, you can see our video about DMXKing receiver : https://www.youtube.com/watch?v=wxQn3rdiKVE&t=2s
After the receiver, the signal is standard DMX so all DMX lights can works.
For the second point, the sequencer will act principaly on color, position and strobe of light, but it can work with advanced control.
Best regards,
