Will Photon 2 work with a PKNight CR011R Art-Net Node?
Hi everyone,
I’m new to Photon 2 and trying to build an iPad-only lighting setup for my band.
Current setup:
  • iPad running Photon 2
  • GL.iNet router (used for our XR18 and Mixing Station)
  • 8 generic RGBW PAR lights (7-channel mode)
  • Donner wireless DMX transmitter/receivers
I initially tried using an ENTTEC DMX USB Pro, but after some troubleshooting I realized Photon 2 appears to be designed around Art-Net/sACN rather than USB DMX interfaces.
I’m considering purchasing a PKNight CR011R Art-Net to DMX node and connecting it like this:
iPad (Photon 2) → GL.iNet Router → PKNight CR011R → Donner Wireless DMX → PAR Lights
A few questions:
  1. Has anyone successfully used the PKNight CR011R with Photon 2?
  2. Does Photon discover it automatically, or does it require manual Art-Net configuration?
  3. Any known issues or configuration tips?
  4. Would you recommend a different Art-Net node in a similar price range?
My setup only needs a single DMX universe and will primarily be used for programmed scenes and MIDI-triggered cues during live band performances.
Thanks in advance for any advice.
I purchased the pknight east node blue which means I no longer need a router. I go from photon 2 to pknight to lights all wirelessly. From memory it connects automatically.
I used a raspberry in the past installing OLA and a usb dmx cable bought on amazon about 21 euros, if you then connect a wifi dmx transmitter to the cable that cost very little it works very well
I use the Lightning adapter that has RJ45 out directly to the PKNight
iPad→ Lightning Adapter→ (ethernet cable) PKNight → Par Lights and mini spots
