After patching in our fixtures (Had to be custom made fixture profiles) they were working fine for at least a little bit but after that every time we used the dimmer inside the group there was a weird flickering problem while turning down the intensity, this was fixed when using the main fader for the group on the “Light Control” panel
I have the same issue.
Does it only do it in live mode? (that’s the case for me)
Interestingly, it only does it with some lights. Not all.
It is driving me mad.
Go to the Device Settings of the shuttering lamp and erase the Shutter function. Add a custom function instead for the same intense. Same Channel etc. If you need the Shutter\ Strobe Function you can program it over those new custom function.
I guess Photon sends while it fades (live mode) Shutter values which could be wrong depending on the fixtures.
